case sc hitch
kirk wannemache
10-29-2004 03:42:28
I was looking at a case sc (1949) the other day and the guy wanted $700 for it. The tractor seemed to run good. I seen a lot of disscusion on this site about eagle hitches. I don"t know what kind of hitch is on this tractor but it"s different than a 3 point. Dosen"t really sound like a eagle hitch though. I was curious if someone knew what type they put on this tractor and what type of attachments this accepts.thank you
Glenn F.
10-30-2004 18:49:02
 Re: case sc hitch in reply to kirk wannemacher, 10-29-2004 03:42:28
'49 was the first year for hydraulics on a DC? Wouldn't this be true for a SC also? If so, it would not have a motor lift. Glenn F.
dctom
10-29-2004 07:06:02
if it is a 49 all you have is a swinging drawbar and a motor lift to raise and lower mounted implements
todd hamilton
10-30-2004 08:28:14
 Re: case sc hitch in reply to dctom, 10-29-2004 07:06:02
Since I have IH blood also in my veins I found it much easier to make a 2-point hitch with the motor lift and bail than a 3 point. No where to make a real sturdy top-link on SCs that did not have eagle hitch. Take the right pin on your implement, replace it with a longer one and face it to the center of the tractor it will line up on the bail. Use an adjustable turn-buckle from the bail to the back of the implement to keep it from flipping back. You have two positions, up and down. Down is "float." I have a light 7' blade on my 44' SC. It is great for plowing snow and light grading - you just can't "cut" with it. TSC will have everything you need to fabricate it. Be sure to use at least one of the orginal tension springs to control the drop speed along with your engine RPM. Be prepared to do a lot of transmission shifting.
ps from todd
10-30-2004 08:37:49
 Re: case sc hitch in reply to todd hamilton, 10-30-2004 08:28:14
You will probably also need to adjust the length of the rod that connects the motor lift arm to the bail. In the original configuration the bail is almost at 12:00 in the up position. I added a couple of links to adjust it to 11:00 (up) and 8:45 (down). It also helps the motor lift not to bind. You can experiment with the position with the tractor off and the transmission in neutral. Engage the PTO and engage the dog gear in the lift motor by pushing the little pedal under the seat. With the clutch out (engaged) turn the belt pulley by hand and watch the lift motor turn 1/2 revolution to adjust the position of the bail.
kirk wannemacher
10-29-2004 08:17:34
The serial # is 5332072sc. Any info would be helpfull as I am new to case. What was the motor lift for. Did it have attachments. Did anyone ever hear of someone trying to buid a 3 point on this and if it worked.Thanks
C. Amick
10-29-2004 08:48:40
 Re: case sc hitch in reply to kirk wannemacher, 10-29-2004 08:17:34
I put a 3-point hitch on my SC that has the hydraulic lifting bail. The hardest part was, I had to add an additional hydraulic cylinder to the right side where all the load is. If you don't, you will bend the lifting bail if you try lifting a heavy load. The factory cylinder is on the left side of the tractor. The hydraulic pump runs off the PTO, so you will not have live hydraulics. The good news is, you will have down pressure and lots of lifting power.
C. Amick
10-29-2004 05:48:08
If you could get us the serial number, we can tell you what type of factory hitch it is supposed to have on it.
