400 Case
Peter Hall
10-28-2004 18:10:48
Im rebuilding a 400 Case diesel with the block stamped 6400-A .the head gaskets they sent were close but didnt line up on the head bolts.Can anyone help?
Pete
RobertTX
10-29-2004 07:05:50
 Re: 400 Case in reply to Peter Hall, 10-28-2004 18:10:48
I have not worked on a 400, but the 500s have two different head castings and there are two different gaskets for them. Since the early 400 was 2/3 of a 500 engine, the same situation may exist. Check the casting numbers on your heads and use a Case parts book to check. Good luck.
John Saeli
10-28-2004 19:06:28
Hey Peter: I'll bet you are using aftermarket gaskets. I had the same trouble. After 2 tries to get the correct ones, they told me I didn't know what I was talking about. Had to get the correct gaskets from CASE.
neale
10-30-2004 05:50:43
 Re: 400 Case in reply to John Saeli, 10-28-2004 19:06:28
put head gaskets on 3 400s with the 6400 block-----got all gaskets from IH dealer and all went well---the same gaskets work on gas and diesel
