Vac high pressure Hydraulic system???
Bunky (MI)
10-28-2004 10:15:09
Where does the Hi pressure hydraulic system get fluid from??
Is there a resevoir on the belt pulley pump??
If so how do you fill and Check it???
Joe (Wa)
10-28-2004 13:09:35
 Re: Vac high pressure Hydraulic system??? in reply to Bunky (MI), 10-28-2004 10:15:09
On the pumps I have seen the reservoir is in the pump. Dipstick is on the top attached to the underside of the breather plug. Fill to the full mark on the dipstick with the ram fully retracted. Factory oil was SAE 10w.
Joe
C. Amick
10-28-2004 13:07:30
The belt pulley housing is the reservoir. Hydraulic oil, Dextron automatiic transmission fluid, and probably even motor oil will work in the pump. It should have a diptick to measure the fluid level. The dipstick is mounted to the large hex nut that is on top of the housing located between the belt pulley and the metal side panel. You fill it through this same opening.
