Vac oil pressure
Bunky (MI)
10-28-2004 03:16:46
How much oil pressure is a Vac supposed to have????
Keith-OR
10-28-2004 20:33:23
 Re: Vac oil pressure in reply to Bunky (MI), 10-28-2004 03:16:46
lotst of good info on the site
HTH...Keith
Joe (Wa)
10-28-2004 10:25:13
Factory spec is 12-20 psi @ full load rpm 1425 with engine at operating temperature.
Joe
Paul f
10-28-2004 06:08:38
Not Much!!
Seriously VAC are a low pressure system. 18-20 is good. Think I read that anything above 14-15 is acceptable
Paul f
10-28-2004 06:20:40
 Re: Vac oil pressure more in reply to Paul f, 10-28-2004 06:08:38
Checked manual...said any pressure below 10 lbs you should stop operation investigate and repair.
