VI plug wires
jhill
10-27-2004 14:52:00
I am working on a VI. I want o be sure the wires are in the cap correctly. Currently the no 1 plug wire is in the front hole in the cap and it goes 1432 counterclockwise. Is this correct.
Alberta Mike
10-27-2004 16:03:19
 Re: VI plug wires in reply to jhill, 10-27-2004 14:52:00
You must be talking about a distributor ignition since you mentioned the "front" hole, I assume that is the one facing the front of the tractor right? Actually, any of the 4 holes could be the #1 hole depending on how the distributor was dropped into the engine to hook up with the cam drive gear. Once it's in there, the #1 hole would be the one which the rotor points to when the #1 cylinder is at Top Dead Center. After #1 is in place, the others go in the firing order in the direction of rotor movement when the engine is turning.
jhill
10-27-2004 18:22:59
 Re: VI plug wires in reply to Alberta Mike, 10-27-2004 16:03:19
I guess what I want to know is how did they come from the factory?
Alberta Mike
10-27-2004 18:45:35
 Re: VI plug wires in reply to jhill, 10-27-2004 18:22:59
I thought maybe that'shat you were wondering about. I wasn't even aware that any of the V series were distributor ignition. I have a standard V and it (plus all others I've seen) are magneto ignition. Apparently the original Splitdorf mags were a real headache. How does the VI differ from my standard V?
jhill
10-27-2004 20:26:34
 Re: VI plug wires in reply to Alberta Mike, 10-27-2004 18:45:35
It's actually a VAI I guess. It is an industrial model. It has a a solid wide front and some other differences. Parts book I have shows both distributor and mag ignition.
Paul f
10-28-2004 06:19:19
 Re: VI plug wires in reply to jhill, 10-27-2004 20:26:34
If you have the Case OHV engine (VAI) then distributor has #1 at just before 3:00 (looking down at distributor)#3 just before 6:00 followed by 4 near 9:00 and 2 closest to the block
Dale(MO)
10-28-2004 06:07:29
The V-series used a Continental F124 flathead engine, while the VA-series used a Case overhead valve engine. As far as I know, engine parts (including ignition) won't interchange. I own a VC, but don't know a lot about the VA's.
