DC4 Case
Jay (ND)
10-27-2004 11:20:33
I would like to learn a bit more about my grandpa's DC-4, but first I need to find out where the serial # is. It's pretty dark in the building and the tractor is greasy, so if anyone could narrow it down a bit, it would be appreciated.
Don Rudolph
10-27-2004 11:47:41
 Re: DC4 Case in reply to Jay (ND), 10-27-2004 11:20:33
The serial num ber plate is on the dashboard, right in the center, and directly under the battery tray. It is a little tough to see in the dark. Also, many times the first number is partially hidden by the rivet that holds the plate down. Another way to tell the number (if the motor is the original) is to find it stamped on the engine flange that bolts onto the transmission near the air cleaner. This number cand be hard to see also, especially if the tractor has been repainted. If the numbers match, you have the original engine. DC Tom can usually tell you the build date, etc. from the number.
Jay (ND)
10-27-2004 11:57:07
 Re: DC4 Case in reply to Don Rudolph, 10-27-2004 11:47:41
Thank you sir!
I'm pretty sure it's original, my dad tells me Grandpa bought it 1 year old. It's never had a paint job, but yet, looks amazingly good. I will look in those spots and then ask DC Tom about it.
If I can free up some garage space, we'll probably restore it just because it was Grandpas.
Don Rudolph
10-27-2004 12:17:50
 Re: DC4 Case in reply to Jay (ND), 10-27-2004 11:57:07
Jay,
I highly recommend restoring that DC 4. They are a great machine and it is always nice to keep a family heirloom in the family. If you need any parts or advice there are plenty of people on this board that can help. Good Luck!
