VAC Project: Need some part nos.
F-I-T
10-26-2004 16:19:18
Folks:
I have a seeping rt rear axle seal. I wanted to order a new seal, and was given V20403 or A30529 for numbers. But, when I try the part number on the dealer website, neither number comes up good.
Anyone have a fresh number or a CR or National number for me?
Thanks as always!
Frank
F-I-T
10-27-2004 07:31:21
 Re: VAC Project: Need some part nos. in reply to F-I-T, 10-26-2004 16:19:18
Okay, so here's what has happened:
Paul: Looks like we need to update your sheet for that P/N. I'll do that.
Yes, Joe, I was finally getting around to ordering that plastic end thingy for the pump and got it confused on my note paper with the seal. I'll have another beer.
I have bought at my NAPA store and they have a pretty good book.
Anyway, thanks to all for your help!
Frank
Paul f
10-27-2004 06:52:48
Frank: My VAC parts manual R.I. C61 page 52 shows VT3749 as rear axle seal.
Chicago Rawhide Xreference comes up with 25745
Depot Parts crosses the VT3749 to A30529..which is apparently incorrect (Thanks to Joe for finding the correct new Case #)
The A 30526 Joe found crosses by CR to the 25745
Isn't trying to find part numbers fun????
Paul f
MikefromIowa
10-27-2004 06:01:16
You can also go to NAPA. they can look it up for you.
Joe (Wa)
10-26-2004 22:21:18
Frank, there seems to be a typo involved somewhere.
Oil seal - axle outer:
Case cross-ref manual VT3749 = A30526
Parts Depot cross-ref VT3749 = A30529 (I think the 9 should be a 6) see below.
Case cross-ref manual A30529 = VT3769 bushing - pinion gear.
Paul f has VT3749 crossing to CR p/n 25745. I don't know how he did that but you can look at the dimensions for that seal @ the link page 27.
V20403 = A30760 is the p/n you were looking at after the 7th dark beer. That is the plastic end cover gasket that you were suppose to replace on your hydraulic pump two months ago. BTW the cover capscrew torque is 35 ft lbs.
Joe
Joe (Wa)
10-26-2004 23:19:14
 Re: VAC Project: Need some part nos. in reply to Joe (Wa), 10-26-2004 22:21:18
This a newer CR searchable data base that recognizes the later Case p/n's.
Ron in mid MO
10-26-2004 19:57:34
I wrote this number down awhile back. National-15445 Hope this helps. Ron
mj
10-26-2004 18:58:34
Paul f did a list of seals and cross references (p. 4 on this forum as of now) on the 18th of this month, might be what you're looking for.
F-I-T
10-26-2004 19:31:22
 Re: VAC Project: Need some part nos. in reply to mj, 10-26-2004 18:58:34
Unfortunately, those are numbers from Paul's list. I think they are correct, might just be a problem with the dealer's parts list.
Frank
mj
10-26-2004 20:08:00
 Re: VAC Project: Need some part nos. in reply to F-I-T, 10-26-2004 19:31:22
Roger that.
