Super Diesel ?
markloff
10-25-2004 22:23:29
What is the difference between a case 400 diesel
and a case 400 super diesel? I"m interested in purchasing a 1957 Case 400 diesel. Would that be a diesel or a super diesel. Did they ever make a
super duper diesel?
Thanks, Mark
markloff
10-26-2004 16:31:12
 Re: Super Diesel ? in reply to markloff, 10-25-2004 22:23:29
would serial number 8100250 be a super diesel or not?
Don Rudolph
10-26-2004 20:41:46
 Re: Super Diesel ? in reply to markloff, 10-26-2004 16:31:12
Some things to look for: is the toolbox smooth topped or does it have Case embossed on it? What is the RPM of the diesel pump? According to the serial number it is not a Super. Don
Doc Larry
10-26-2004 19:25:03
My parts book shows the 400 Super starting with #8106131.
Larry
Don Rudolph
10-26-2004 11:12:41
The super diesels were made at the end of the production run. I can't give you the serial numbers here at work, but there are a few ways to tell one. You can't rely on just the hood decals, for sure. The most obvious way is the steering column support will be painted orange and have a round cast piece where the future Case-o-matic lever will bolt onto (on the 800). The Supers had more cubic inches, higher Rpm, larger tool box, and supposedly better hydraulics. The block will have the number 4111 stamped on it. It is the same block as the 700 and 800. The supers also have a PTO brake-I don't believe the regular 400 had one. I recently redid a super diesel and really like it. We use it on the farm almost daily. Don
