DC brake seals
SHeiserman
10-25-2004 20:04:16
Anybody know the # for the seals on a 49 DC? Before I tore it all apart, I went to a dealer to order new seals. He sold me four seals and two o-rings. As far as I can tell, all I need is two seals (one each side). Neither of the seals he sold me is right. Part # A50422 is the right O.D., but the rubber seal doesn't touch. The red paint parts pushers tried, but it isn't quite right. MAYBE if I have a number, I'll be able to get the right seal. Thanks.
Paul f
10-27-2004 07:23:30
 Re: DC brake seals in reply to SHeiserman, 10-25-2004 20:04:16
Your parts guy may have looked at later models...My DC (1953--8025000) does have two seals and an O ring on each side
Tom's part number crosses to CR seal 27368
Haven't tried to replace mine (one side seeps a little) as it looks like a major job
Don't know about foil but have heard of using thin plastic to protect the seal as it slides over shaft..would have to be tough enough to be pulled out without tearing...or only put it up to the surface the seal runs on.
SHeiserman
10-27-2004 15:59:34
 Re: DC brake seals in reply to Paul f, 10-27-2004 07:23:30
Good tip/s, seems rather obvious now. I've got two numbers now, should be set. Thanks Paul.
Tom Railsback
10-26-2004 18:49:16
The number I have written into my DC parts book is A27130 which suceeds O7041AB. (the original number)
SHeiserman
10-26-2004 19:39:06
 Re: DC brake seals in reply to Tom Railsback, 10-26-2004 18:49:16
Thanks much, Tom. Parts guy looked thru two different books to come up with what I bought. I'll give him that number and see what he says. Somebody here had recommended putting aluminum foil on the shaft to protect the new seals. Once I get new seals that actually seal, will that foil come back off without a problem?
Don Rudolph
10-26-2004 11:19:27
Scott,
Can't help you with the seals, but wanted to let you know that I could not contact you back by e-mail again. Don
SHeiserman
10-26-2004 19:30:49
 Re: DC brake seals in reply to Don Rudolph, 10-26-2004 11:19:27
I fired one off to you. Hope it works.
