Antique tractor auction comming Nov 13, 2004 in Belle Fourche SD. I will attempt to post the needed information. caseman-d
Click Here To Print Auctions
Elson Implement Collectible & Antique Tractor NO SMALL ITEMS - TRACTORS ONLY! Location: Belle Fourche, SD - From Junction of Highway 85 and 212 - west on 212 - 1 1/2 miles - north side of road. SAT., NOV. 13, 2004 Starting at 1:00 p.m. MT AUCTIONEER'S NOTE: Elson Implement will be offering nearly 60 tractors at public auction. These tractors are subject to prior sale up to 3 days before sale, so inventory may change. Elson Implement specializes in collectible tractors and machinery parts and inventory may be viewed. (Including sale day tractors) at www.ElsonImplement.com - SD Sales Tax will apply. Lunch will be available CASE TRACTORS Case 600 - #8105 351, diesel, PTO
Case 900 - #B812 3895, good dash, 2 hydraulics, straight, good rubber Case 900 - #B-8148355 Case 500 - #8037600, diesel, runs good, sharp Case DC4 - #5611009 - complete Case DC4 - #5610321 - complete, not running, with Eagle hitch Case VAC - #4931084, narrow, complete Case 930 CK, - #8199128, standard, runs Case L - #L323260 Case LA - #5331613 - gas, engine turns Case S - standard FORD TRACTORS 8N Ford with loader and rear blade 8N Ford - 1952 - overhauled and sharp 8N Ford - runs good 2N Ford - runs good 2N Ford with loader, shifter problem, runs good 2N Ford with loader, runs good 9N Ford #17598, runs good 841 Ford Power Master
MM TRACTORS MM M5 - #17104942 - propane, adjust front, good rubber, engine turns MM G900 Wheatland #29703019 - runs good, diesel MM UB #05804064 - wide front, runs MM U - #UTU-0114902349, hydraulic, gas, complete MM G MM U MM Z STATIONERY ENGINE & TRUCK 1940 Chevrolet truck, restoration special, no title
JD 1 1/2 Stationary engine, model type E, sharp! See You At The Auction! IHC TRACTORS IH 660 IH WD6 - #WDEK39867, runs with DuAl loader IH W6 - #WVK 4077WI - not running IH W9 - engine not stuck IH W6 - #BK2949I WI - complete, except for head, straight IH W9 - #CB53552W12B - hydraulic, good rubber, straight, stuck IH 650 diesel - unknown McCormick 10-20 - #KC144415 - not running, but complete, except side curtains IH Farmall A #29567 - parts missing McCormick W30 #WB259-20P - complete, not running IH 300 Utility #23359SJ - TA, runs good, quick hitch
JOHN DEERE TRACTORS JD 720 diesel, #7221040, PS, rockshaft, factory wide front, straight, runs good, pony needs work JD G, #19448, rockshaft, not running, complete JD B, #B240885, good rubber, runs JD AR, #274453, runs JD A, #450931 - complete, except carb JD B, #50723 - complete except mag JD 60, #6018402 - runs, factory wide round front end, straight, gas JD 60, #6055306, runs, factory wide round front end, runs good, no rear fenders, 18.4 X 34 rears JD MT, #MT19100 - looks and runs good JD 620, #6214767 - PS, gas, looks and runs good, factory 3 pt., square wide front JD 730 Diesel, standard, runs good JD 830 Diesel, runs good OTHER TRACTORS Oliver Cletrac - #ADSZ526, diesel, not stuck Oliver Cletrac - #DGH 3E 062, XC Hercules engine Oliver Super 88 - #10575-801, diesel, runs MH 44 - #44DS 5820, diesel, runs good MF 97 - #23705213, diesel, runs good, 6 cylinder AC WC - #165361, complete OWNER: ELSON IMPLEMENT Belle Fourche, SD � 1-605-892-2795
