SC Drag Link Length
Glenn FitzGeral
10-23-2004 21:19:06
On an earlier thread I was trying to figure out why my SC adj. wide front has to have one tie rod 1 1/2" longer than the other to steer straight. Someone suggested the AWF has a longerr drag link. The drag link that came with my AWF and the one from the factory narrow front are both 67" long. Did I receive the correct drag link with my AWF? There are very few explanations I can think of for this prroblem. Your input is greatly appreciated. In order to get my wheels running straight and the tractor turn equally both ways is to cut a piece out of one tie rod. As it is I cannot shorten it enough. Thanks, Glenn F.
Mike Schwartz
10-25-2004 20:06:18
 Re: SC Drag Link Length in reply to Glenn FitzGerald, 10-23-2004 21:19:06
Hello, I measured the drag link on my '42 AWF SC and came up with just under 67 inches. I will check the '48 and see how it measures up. Good luck, Mike (WA)
Don Rudolph
10-24-2004 08:48:45
Glenn,
I hate to say this but I would cut and weld the drag link so that it works right. Its the same as my problem with the front arm on my AWF. After awhile you will just forget about it and nobody will ever know the difference unless you tell them. Quite a storm yesterday!!! Don
