A201G Case Combine engine
JerryW
10-22-2004 17:36:27
I have access to a complete running A201G gas engine out of a combine. What series tractor if any does this motor fit and what is it worth? Includes bell housing and radiator.
Jerry
John Saeli
10-23-2004 10:58:46
 Re: A201G Case Combine engine in reply to JerryW, 10-22-2004 17:36:27
Hey Jerry: It's worth quite a bit. Will not fit any tractor without some modification to the tractor because the 201 block is about 2" longer than the blocks used in the tractors. They have been successfully installed.
JerryW
10-23-2004 19:29:59
 Re: A201G Case Combine engine in reply to John Saeli, 10-23-2004 10:58:46
John
The guy wants probably $400 for the whole works and it appears to be a very low hour engine.
I was thinking of shoehorning it into my VA loader tractor which is weak in the engine department and could use more hp anyway. I am not worried about the length and it seems to want to fit into a VA. I think I would have to spend at least that much to overhaul my engine.
Thanks Jerry
DCTOM
10-23-2004 15:59:27
JOHN; I THINK THEY ARE THE SAME AS THE I88 ENGINE AND WILL FIT ANY TRACTOR THAT HAS THAT WITH NO MODIFICATION TOM
