Hey Don L Can You Help????
Brad From Austr
10-22-2004 01:42:14
Hi Don
Please follow link, I've been told you may be able to help>
Cheers Brad
Don L.
10-23-2004 07:55:35
 Re: Hey Don L Can You Help???? in reply to Brad From Australia, 10-22-2004 01:42:14
I would have a bunch of them in the heads. I have yet to get any out. What is the secret to get them out? I have tried other times.
Don L.
Brad From Australia
10-23-2004 22:27:18
 Re: Hey Don L Can You Help???? in reply to Don L., 10-23-2004 07:55:35
Don What condition are the heads in as a whole. If they are in good condition I could purchase them whole and save the risk of damaging the powercel.
Caseman
Case dealers here in Australia are basically useless, I've suggested they order out of US but they can't comprehend that. They order out of Melbourne and if they don't have stock then basically that's it. That's why I'm trying to get some in the US.
Cheers Brad
Brad From Australia
10-23-2004 22:20:43
I have taken my set to local engineer to have them pressed out, not sure how he's gotten on yet. Looking at them I would say you could press them out through the injector hole. If you are familiar with the 500 heads they rot out in the powercel chambers, if you have any with very little or no signs of corrosion I will buy six if possible. Thanks for your help.
Cheers Brad
caseman-d
10-22-2004 11:21:14
Brad the head gaskets are available from any Case IH dealer. They need to have the casting numbers off the heads as there are two different heads for the 500's. Not sure about the powercel. I show the following numbers
O9794AB cap
O9795AB screw
O9796AB pin
4601AA body
Iwill check numbers when I go back to work.
caseman-d
