massey V8,s,and Case 2390,or 2590,
kirkC
10-20-2004 10:32:17
I like both kind,s of tractor,s,
I love those Massey V8,s,and I like the Case
23,and 2590,s too,
Are the Massey,s hard to deal with?
Or should I get a case, and be done with it?
I am in a fiddle over this decision?
Im looking for a clean one of each out there, and I havent seen too many of either,
Please Help,
Kirk C,
Jim M
10-21-2004 09:41:28
 Re: massey V8,s,and Case 2390,or 2590, in reply to kirkC, 10-20-2004 10:32:17
We had a 2805 M/F that split the rear end housing in half when we got enough weight and tires on it.
Had triple 20.8 x 38 tires with the inside 2 full of fluid and a big cast weight on the rear wheels.
Had a 2390 Case. Had to rebuild the power shift once but that was all.
Leland
10-20-2004 21:25:56
Drove both I would rather have a 2590 they will pull the hinges of of he11.plenty of power and with enough weight they handle a 14ft chisel good
Can't even use my name
10-20-2004 20:12:11
I'd opt for the Case myself. Never had a Massey other than our 1800 (articulating 4-wd with a Cat) but we have had over 12 Case's with powershifts. Been actually really trouble free. But just this year I had one shear off the bolts that hold the clutch pack together and one had a weak torque limiter belleville spring which ate up the torque limiter ring. Not too bad price wise to fix myself. Not too hard either. We do have a 2390 and it will lug and lug and lug some more. Has 20.8 X 38 Radial duals and will get them suckers spinning if get it in a hard pull... lots of power! I think it is running near the horse of a 2590 actually. Good solid tractors.
fixerupper
10-20-2004 17:54:24
My neighbor had a Massey V8 two wheel drive tractor, I don't remember the model #, and he said it was awful noisy in the cab. V8 diesels haven't been successful through the years and I don't know why. Maybe one of you guys can fill us in on that. The Cases must be pretty good, since I see more old Cases around than Masseys.
big orange
10-20-2004 16:49:12
The V-8 Massey is a good engine,problems come from the flywheel back.Taken care of the 23-2590 are a good tractor.
John Saeli
10-20-2004 17:09:13
 Re: massey V8,s,and Case 2390,or 2590, in reply to big orange, 10-20-2004 16:49:12
Isn't That M-F V-8 is a Perkins? What Cu In is it? I looked @ a MF 4800 last week. It had a 903 Cummins in it.
big orange
10-20-2004 18:50:38
 Re: massey V8,s,and Case 2390,or 2590, in reply to John Saeli, 10-20-2004 17:09:13
Believe it's a Perkins,540 cu.in.rings a bell.
CK Richard
10-20-2004 15:50:24
It's going to be hard to get a neutral answer on this case forum ,any way I here those V8s are $$$$$ to work on
