brake seal leak
DC3PULLER
10-20-2004 07:10:15
Hey does anyone know what I cant put in my DC"s rearend oil to stop my brake seal fom leaking ? ITs not to bad of a leak and I hate to skin up my fancy paint job tearing it down and putting in a new seal.thanks
C. Amick
10-21-2004 09:49:50
 Re: brake seal leak in reply to DC3PULLER, 10-20-2004 07:10:15
First make sure you don't have too much oil in it. I don't know of anything you can add to your oil. The SC's have a overflow hole on the bottom where the circular metal brake disc bolts against the main tractor housing. I don't know if DC's have this same opening. If the hole is open, all the excess oil should come out down low where it isn't as visible.
DC3PULLER
10-21-2004 11:00:37
 Re: brake seal leak in reply to C. Amick, 10-21-2004 09:49:50
That is wear the oil is coming from . IT is a drain incase your seal starts to leak that way you don"t ruin your brakes. This tractor just started to leak after 5 years so I know its the seal.Didn"t know if anyone had a magic potion I could use
C. Amick
10-21-2004 13:23:05
 Re: brake seal leak in reply to DC3PULLER, 10-21-2004 11:00:37
The only other wild idea I have is to run a small piece of copper tubing into the overflow hole and let the end of it protrude an inch or so out beyond the tractor body. That way, perhaps the oil will drip out the end of the tube and not get on the tractor?
