Case DB 1490
Mike Sheehan
10-18-2004 16:07:30
I have a problem with a noisy power steering unit on a David Brown 1490. There seems to be a lot of vibration in the hoses leading from the power steering pump to the control unit in the cab. At low revs it's not too bad but as you increase revs noise (buzzing sound) in the cab gets pretty bad. Does anyone know the cause of this, poor oil flow or resonance perhaps, and if so what would be the cure?
Thanks,
Mike.
Mike Sheehan
10-26-2004 15:52:16
 Re: Case DB 1490 in reply to Mike Sheehan, 10-18-2004 16:07:30
Thanks Elmer, had a look and it seem ok, clear with no foam. I have a spare valve unit which I'm going to swap out to see if that will help, just means taking the dash off to get at it.
Mike
Elmer
10-20-2004 16:46:13
Check to make sure your steering fluid is not foaming. It could be sucking air from the shaft seal of the pump. It may be black from engine oil.
