Seals for VAC and DC
Paul f
10-18-2004 15:00:53
Not all of us are blessed with an auto parts store that can find cross references for Case seal numbers. I also appreciate the help from members of this board. I have been doing some research on seals and have come up with a list of cross references. I have created an excel spread sheet with old and new (when available hidden on the paste job below) case numbers and both Chicago Rawhide and National (also hidden on paste job below to make it somewhat readable)numbers. I found several VT series that are not in my VAC parts manual so I have no descriptions for them...(If any of you can help fill in the blanks...)
The spread sheet doesn't paste well here I can email it to any one interested...or if there is a better way to post it....
Also found a very nice firm to get seals from
EB Atmus... www.ebatmus.com
Ordered via internet and seals showed up UPS 1 week later...cheaper than Case.
Paul f
Old Case# Noun Chicago Rawhide#
O3873AB Outer Differential (Brake) Shaft DC 28686
O4240AB Steering arm shaft seal VAC 13614
O4253AB Rear Axle Seal DC 34283
O7610AB Belt Pulley Shaft DC 19301
O9345AB Inner Differential (Brake) Shaft DC 28697
VT2090 17557
VT2095 21098
VT2115 11776
VT2233 13612
VT2316 Belt Pulley Shaft 15748
VT2817 Oil Seal - Ram (VTA-633) 9998
VT2905 4985
VT3249 33712
VT3373 Crankshaft front 21143
VT3401 11801
VT3460 26209
VT3465 Differential Shaft (brake) VAC 22446
VT3502 26209
VT3520 PTO Shaft VAC 13739
VT3525 6203
VT3555 13614
VT3688 9876
VT3749 Rear Axle Seal VAC 25745
VT3756 Belt Pulley Hydraulic Pump 13650
VT3757 Belt Pulley Hydraulic Pump 13650
O5086AB Clutch Shaft Seal 9876
O3899AB PTO Shaft Seal 17442
O3869AB 4" Cylinder seal 11170
C. Amick
10-20-2004 09:45:56
 Re: Seals for VAC and DC in reply to Paul f, 10-18-2004 15:00:53
Thanks for the information. I would appreciate you emailing me the Excel spread sheet, if you get a chance.
mj
10-18-2004 16:42:29
Thanks for the effort and the info!
