Can I use heavy gear oil in 930 trans??
R Wyler
10-17-2004 17:02:15
My 66 model 930 6 speed has some leaks it leaks through the gear shift shaft and also on the right side where a shaft comes through the trans case would 80-90 or 84-90 gear oil be ok to put into it? I imagine it would slow the leaking down and also lubricate it well when useing it for discing and plowing in the hot summer. Would this work ok?? Thanks, R Wyler
Jim P
10-17-2004 21:38:17
 Re: Can I use heavy gear oil in 930 trans?? in reply to R Wyler, 10-17-2004 17:02:15
I put 80-90 oil in my 930 six speed tran at 2500hrs and now have 8500hrs and have never changed it. probably should but have had no problems and never opened the trans.
R Wyler
10-18-2004 06:11:50
 Re: Can I use heavy gear oil in 930 trans?? in reply to Jim P, 10-17-2004 21:38:17
That is alot of hours though that heavy oil shoukd last a very long time in something like that. Those old Case chain drives run indefinatley and never wear out. GRIN.
John Saeli
10-17-2004 19:20:52
Hey R. Wyler; I'd use 85W140.
R Wyler
10-17-2004 19:24:09
 Re: Can I use heavy gear oil in 930 trans?? in reply to John Saeli, 10-17-2004 19:20:52
Thanks John I'll do just that. Is there any way to check the oil level in these 6 speeds?? I know on my other 6 speed 930 that little pipe plug on the rear where the pto hyd houseing bolts on is I can remove it and nothing comes out and that is after filling it to 15 gallons and 1 quart like that manual says. Do you have any advice on this? Thanks again. R Wyler
John Saeli
10-18-2004 10:27:44
 Re: Can I use heavy gear oil in 930 trans?? in reply to R Wyler, 10-17-2004 19:24:09
Hey R. Wyler: I don't even measure anymore, I just fill till the oil comes up to the plug hole.
R Wyler
10-18-2004 14:03:49
 Re: Can I use heavy gear oil in 930 trans?? in reply to John Saeli, 10-18-2004 10:27:44
Thanks John that sounds good to me. :>) R Wyler
AllanC
10-17-2004 17:23:47
Don't these use the gear oil for the hydraulics? I can't remember. If it does, stick with the hy-trans.
R Wyler
10-17-2004 17:26:35
 Re: Can I use heavy gear oil in 930 trans?? in reply to AllanC, 10-17-2004 17:23:47
On these chain drive tractors the rans/rearend is a seperate compartment from the hyd. Though if they were in the same compartment it would indeed not be possible to use heavy oil in it. Thanks for the followup. R Wyler
AllanC
10-17-2004 17:41:21
 Re: Can I use heavy gear oil in 930 trans?? in reply to R Wyler, 10-17-2004 17:26:35
If it's a chain drive it should be no problem to use heavy oil. The old L used 140 weight. Didn't shift too well in our Sask cold, but nobody used a tractor much in the winter.
R Wyler
10-17-2004 17:52:43
 Re: Can I use heavy gear oil in 930 trans?? in reply to AllanC, 10-17-2004 17:41:21
Yes since the old L and LAs used it the 930 6 speeds should be fine with it. I think that is what I should do. Thanks. R Wyler
