430 ENGINE SWAP
Rod Lewis
10-17-2004 06:52:48
Hi Looking for info on which if any motor out of say a Case combine or swather that would be a bolt in to replace the motor in my 1963 Case 430 gas. Thanks for any and all info.
Illini Case
10-17-2004 17:56:58
 Re: 430 ENGINE SWAP in reply to Rod Lewis, 10-17-2004 06:52:48
your 430 probably has a 148 motor. It is a real pain to change to any other motor because the length of the 188 and 201 motors are about 1-3/4 inches longer than your 148. Thus front wishbone has to adapted, steering has to be adapted, and the hood has to be lengthened. If your 430 was a 188 diesel it would be an easy swap out. Another thing is if you get an older 148 motor you have to get the flywheel to as there was a bolt pattern change from the old 148 to the newer 148.
Rod Lewis
10-18-2004 05:16:43
 Re: 430 ENGINE SWAP in reply to Illini Case, 10-17-2004 17:56:58
Hi thanks for the info. Another question how do I find out if I have a 148, 188, or a 201 ? Rod
mike's600
10-19-2004 03:43:59
 Re: 430 ENGINE SWAP in reply to Rod Lewis, 10-18-2004 05:16:43
I have a 148 ,needs rebuild for sale
Illini Case
10-18-2004 20:53:32
The 430 gas was a G148B only. The 530 gas had a 159 cu. in. The 430 & 530 diesels were the 188 cu. in. There are some salvage 148 motor's out there but I would say rebuild what you have ...if at all possible.
mike's600
10-17-2004 10:14:59
If your 188dsl has a three bolt starter, a 188 gas or 201 gas should bolt up. I put a 188 gas in a 530 case, and it worked just fine.
