VAC cylinder head
jpnk985R
10-16-2004 17:09:14
I need a cylinder head for my "49 VAC Case. The old one is casting VT148. An acquaintance tells me that a newer head, casting G1160 will work. Is he right?
The bolt pattern is the same, and everything looks right, but I want to know for sure before I have work done on the G1160 head.
MMB
10-17-2004 05:07:14
 Re: VAC cylinder head in reply to jpnk985R, 10-16-2004 17:09:14
Where abouts do you live? Shipping a cylinder head could get pretty darned expensive if you weren't in the vicinity. I have one here that I believe is the correct head. I'll remove the "hide" feature from my email address.
jpnk985R
10-17-2004 08:07:26
 Re: VAC cylinder head in reply to MMB, 10-17-2004 05:07:14
My initial message wasn"t clear that I already have the G1160 head. I"d like to not have to buy another one, shipping or not, if this one will work. I"v found references to G1148 heads many places, but no references to a G1160 head. Does anyone know what this is off of?
Joe (Wa)
10-17-2004 11:37:41
 Re: VAC cylinder head in reply to jpnk985R, 10-17-2004 08:07:26
Head casting #G1160 is listed in the parts manual as LPG head for 148 cid used in the 300 & 400 series tractor. Most of the upper end components of the 148 cid and 124 cid heads are the same or are interchangeable.
I think it will bolt on ok but don't know what the differences are.
Joe
jpnk985R
10-17-2004 17:56:43
 Re: VAC cylinder head in reply to Joe (Wa), 10-17-2004 11:37:41
I've done some more checking today. The gasket is a match, so I decided to just slide the head on. It all looks ok excetp the push rods are too long. I was reading through old posts on this site and found reference to that when using a G1148 head on a VAC engine. I guess I'll do some more visual on the combustion chamber and maybe get shorter push rods. I guess this would make a higher compression, more power??
Joe (Wa)
10-19-2004 11:27:33
 Re: VAC cylinder head in reply to jpnk985R, 10-17-2004 17:56:43
The pushrod for both the gas VAC 124 cid and the 300 series 148 cid engine are the same VTA864, new p/n is A30259.
The alternate pushrod for the engine is G11086 and is listed in the parts manual for use on the LPG engine.
Cyl head G1160 is listed as for LPG so perhaps the alternate pushrod is the correct length.
Both these pushrods are avail from Case so a dealer should be able to provide the info you need.
Joe
jpnk985R
10-21-2004 08:19:44
 Re: VAC cylinder head in reply to Joe (Wa) , 10-19-2004 11:27:33
Thanks very much for the info. Thanks to everyone for their help!
mikes600
10-17-2004 10:11:22
Take your old head gasket and check it against the other head. I have installed a head off of a 148 engine (311B) on a Vac engine.
JerryW
10-16-2004 21:40:26
If not I have a 1949 VAC engine I would sell and I would take the head off of it. I think it should be good.
Jerry
