need help with this modern stuff
DCTOM
10-16-2004 16:30:48
I HAVE A 400 B CASE-0-MATIC THAT I CANT KEEP OIL IN THE CASE O MATIC PART, IT DONT SEEM TO BE GOING IN TO THE REAR END AS THAT LEVEL NEVERS SEEMS TO CHANGE, AS MUCH HY-TRAN AS I HAVE PUT IN IT HAS TO BE GOING SOMEPLACE ANY HELP WOULD BE APPRECIATED DCTOM
jeremy h
10-18-2004 22:28:40
 Re: need help with this modern stuff in reply to DCTOM, 10-16-2004 16:30:48
i think you are using the wrong oil we had a 411b afew years ago i think we used auto transmission fluid it burnt oil enternally with the hy tran because it was to heavy of oil ps i live at campbellsburg in i would like your phone no.
ChadS
10-17-2004 08:47:29
Tom, was that the same small case that was up at Bremen pull using it for the grader that last time? Is it leaking internally, or externally? Chad
Brian in Ohio
10-16-2004 16:54:16
Don't know if this is the same or not, but my Dad's 430 loses it up through the shifter.
