970 Case Power Shift- Is this normal?
Pat wc IA
10-16-2004 09:38:08
The hydraulic system on my 970 (later white model) Case Power Shift makes a squealing/moaning noise as you let the clutch pedal out. It only makes this noise while the inching spool is modulating the clutch pressure. It dos not make the noise when the clutch pedal is way up or way down.You can put your hands on the hydraulic lines that run to the hydraulic filters and feel the lines vibrate. I have tried changing the hydraulic filters and have replaced the modulating springs and point in the power shift valve. Changing the filters seemed to help, but not totally eliminate the noise. I just purchased this tractor and I do not think it made this noise at first....but I could be wrong about that. Is this noise normal?
Thanks!
Pat
crazy case
10-16-2004 14:41:08
 Re: 970 Case Power Shift- Is this normal? in reply to Pat wc IA, 10-16-2004 09:38:08
yes this sounds normal
