Case Model Help
David Merrell
10-16-2004 07:40:28
I need some help classifying an old Case tractor I recently bought. It was sold as an 885 but I've recently found out the 885 has a four cylinder diesel. This is a three cylinder.
These are the stamped numbers on the right rear of the engine and in this order:
355011
4-05-78
K927071F
8F6
Can anyone help me with this?
Thanks
JRB (TN)
10-16-2004 16:17:35
 Re: Case Model Help in reply to David Merrell, 10-16-2004 07:40:28
You have an 885. I don"t know what year, but the 355011 is the engine serial starting number, same as mine.
The plate that has the information on my tractor (1974 885/1) is located on the toolbox on bottom right below engine. Hope this helps, and Elmer could probably tell you what year it is, as he is the DB expert on this forum.
Tom (Ks)
10-16-2004 09:28:47
The Case-David Brown 885 has a 3 cyl engine.(1971-1980) The other 885 with the 4 cyl must be some Case-IH model, (1985 and up).
David Merrell
10-16-2004 17:11:22
 Re: Case Model Help in reply to Tom (Ks), 10-16-2004 09:28:47
Thanks for your help. Any suggestions where I might go to get needed parts, filters and such.
C. Amick
10-18-2004 09:48:16
 Re: Case Model Help in reply to David Merrell, 10-16-2004 17:11:22
Your Case/IH dealer should have parts.
