Case Rider 214 ...Quality
IdaRed
10-14-2004 20:36:45
Is a Case 214 a good tractor and what year did they build them? This one needs some motor attention on the 14HP Koehler.It comes with a mower deck,snow blower, sweeper and cab: All J.I.Case equipment.
Ida Red
10-15-2004 20:14:38
 Re: Case Rider 214 ...Quality in reply to IdaRed, 10-14-2004 20:36:45
I stand corected the tractor is a 224 and I still need info on it. Thankyou.
John H-WI
10-16-2004 04:07:46
 Re: Case Rider 214 ...Quality in reply to Ida Red, 10-15-2004 20:14:38
As I stated they are generally a good tractor. Koehler parts are available at most small engine repair shops. Many parts such as bearings, roller chains, are available at parts stores that deal in this type of items. The only problems that I had with mine (3) were starter selinoids and the electrical component that bolts to the access plate on the bottom of the dash. Some parts may still be available from Ingersoll. For more information I would suggest you post a question on the Case/Colt/Ingersoll board. There are many knowledgeable folks there.
John H-WI
10-15-2004 17:10:46
They are generally a good tractor. Depending where you live you might have to look a little for parts but they are around. Owned three of them in the past.
