Hydraulic fluid
Patrick
10-14-2004 12:50:40
OK, so I have the new (to me) "67 580CK. I do know from the whine of the hydraulic pump and the sluggish response of the bucket that it is low on fluid. I assume that since it is a high-pressure system that there is no dipstick to check the level. Where do I (a) check the level, and (b) add hydraulic fluid? (c) Where can I sample the fluid to make sure it isn"t milky or corrupted? (d) What type fluid do I need and can I safely add it to whatever is already in there? Lots of basic questions, I know, but I want to do this right.
Esev
10-14-2004 17:11:38
 Re: Hydraulic fluid in reply to Patrick, 10-14-2004 12:50:40
I don't know much about the types of fluid. I use straight hydraulic fluid on the model 33 backhoe/loader on my 68 580CK. I can tell you where it goes in though. The loader frame is your hydraulic reservoir. There is a filler/vent on top of the right hand loader main frame. It is just in front of the loader controls. About half way down on that same frame there is a small pipe plug to check the level with. Also there is a bleeder plug at the front of the loader frame on the right hand side near where the hydraulic pump intake is. I always open both the bleeder and the check plug and watch for the fluid to start coming out the bleeder. Close the bleeder and continue to fill untill it shows up at the check hole. You will be able to tell if it is milky at either of these two points. It likely will be if it is anything like mine !!! I can't complain though. Just about every component on mine shows serious wear, but for what I have into it she gets the job done and saves me some serious $$$$$. Just dug out two 12 inch dia. ash stumps with her tonight. They fought me hard, but the Ole Case won in the end. Take care and good luck with yours.
