Found right sn for DCTOM
Roger A. NY
10-14-2004 05:22:50
Tom I checked the sn for the DO and found I missed typing it. The correct no is 5224972DO. Any info you can come up with is appreciated. Roger
Brian in Ohio
10-14-2004 18:00:22
 Re: Found right sn for DCTOM in reply to Roger A. NY, 10-14-2004 05:22:50
Are you getting your serial number information from the serial number plate, or from the number stamped on the engine. If you look on the driver"s left side, along the edge of the flange where the engine block and transmission bolt together, you should find a serial number stamped there. See if that number matches what is on the serial number plate.
DCTOM
10-14-2004 08:44:06
ROGER, GUESS I STILL LDONT UNDERSTAND 5224972 IS STILL AN LA BUILT AUG 31 1948 AND SHIPPED TO J H MIKHELSON DIVLES LAKE ND SEPT 1 1948 TOM
