case terratrack block 320
tony wilkas
10-14-2004 04:59:42
looking for a block, or rebuildable motor, for a case crawler 320 old block has seral number of 126n04103, also what case gas tractor is this block interchangeable with
Karen
10-15-2004 04:43:14
 Re: case terratrack block 320 in reply to tony wilkas, 10-14-2004 04:59:42
If it's a 320 it should have a Case 148 motor, but there are several different blocks, depending on how old it is. A 320 should have a small journal crank, but it could have had an engine change or a late production engine. Anyway, we man have a block for you but the crank journal needs to be measured.
Gene Dotson
10-14-2004 15:08:57
Tony; My 320 uses a Case G148 engine. Should be the same as used in 300, 400B and 430 tractors... Gene
