sc top link
jon holt
10-12-2004 20:23:50
I am needing a top link for a SC and was wondering if anyone new where I could get one or if one from TSC would work. I dont need the correct one right now just one that will work
Camboted
10-12-2004 21:08:52
 Re: sc top link in reply to jon holt, 10-12-2004 20:23:50
It depends on what implement you are trying to use and how much of a Case "pureist" you are? The Case top link was shorter than the standard category #1 top link. The good news is that most of the cat. #1 implements work fine with the TSC or Farm & Fleet top link (at least on the implement end). I had to extend my Case link to get it to work with a Bushhog. The bad news is that if you are using the Case original top hook (for pto work) or the bottom (which covers the pto) you need to cobble up some kind of yoke or clevis for the TSC top link, as the Case only had a single eye for the pin. It may well be worth it, as the good Case originals go for $100+ on ebay. But, if you are using a genuine Eagle Hitch implement then you might want to look for the Case. LOL!
Paul f
10-13-2004 06:10:11
 Re: sc top link in reply to Camboted, 10-12-2004 21:08:52
For PTO implements using standard Cat 1 link I added a second bracket 09195AB on the other side of the PTO Access cover and got a longer pin from TSC. Because of the height of the top link you will find that some implements won't lift very far... You can try raising the height of the top link connection on the implement...or like me live with it.
My tractor didn't have the PTO Cover /bracket 4205AA and after seeing the price on ebay I had my welder make up a bracket to bolt on the face of the PTO around the shaft which I can use for my back blade and other non PTO implements. For that hook up the standard TSC top link is too long. Bought an extra, cut 8 inches out of tube had it welded back together and cut off some of the screws.
