Case 300 question
caser-up
10-12-2004 19:50:41
Can anyone tell me the purpose of the hand clutch on my case 300 round nose stlye. The lever is by your left leg and the tractor will stop moving if you pull it back. whats it purpose?
Coloken
10-13-2004 07:07:07
 Re: Case 300 question in reply to caser-up, 10-12-2004 19:50:41
Like the others say. Very much needed if you run a PTO bailer or bush hog. Not realy live PTO but works all most as good. The Allis WD had like the same thing.
george md
10-12-2004 21:16:58
Caser, That clutch is part of the system that case calls "constant running PTO " , not to be in any way considered "live PTO " . It permits you to stop the wheels while having the pto continue to
run . It is a multiple disc metal clutch that usually drags slightly making gear changing somewhat miserable. I have one and have had it
since new.
george
Joe (Wa)
10-12-2004 21:09:52
The hand clutch is used to control ground movement w/o affecting the PTO. In other words disengaging the hand clutch disconnects engine power to the tractor transmission but not to the PTO. The foot clutch disengages power from both the transmission and the PTO.
Joe
