Case R parts
Ole B
10-12-2004 15:47:07
I'm about o finish restoring a Case R from 1939 (gray on rubber wheels), but miss some vital parts. Does anybody know where I can get the following items:
- 2 gas tank caps
- needle valve for the gas tank
- oil gauge, stud mounted (like on Farmall H)
- spark plugs
Ole
39CaseR
10-15-2004 04:15:39
 Re: Case R parts in reply to Ole B, 10-12-2004 15:47:07
If it's a '39 i would think it should be flambeau red.
-2 gas tank caps? ,is it deul feul?.I would just start grabbing gas caps that look the right age and when u find one grab two!
-Needle valve? do you mean the sediment bowl?That is not a "R" specific part ,should be able to get that anywhere.
-The same with the oil pressure gauge and the spark plugs ,they are not "R" model parts only.You may have to search for the right style of mount but if you find one the is stud mounted and says case then thats your gauge!Spark plugs ,i got 4 brand new ones from a parts dealer at my local show ,you will not find them at parts source ,or pep boys though.
Ole B
10-16-2004 14:00:58
 Re: Case R parts in reply to 39CaseR, 10-15-2004 04:15:39
Gas tank caps: I got two new for another tractor some years ago - galvanized replicas, I guess. But where can I buy another couple.
Needle valve: No, it's not the sediment bowle under the the big tank, just a simple valve under the starting tank.
Ole B
