brake information for a 1977 case 580c
Don Liebscher
10-12-2004 15:18:41
IAM IN NEED OF INFORMATION CONCERNING THE BLEEDING PROCEDURES ON A 1977 CASE 580C BACKHOE. THE MANUAL REQUIRES A PRESSURIZED BRAKE FLUID TANK TO BE USED.IF THERE IS ANYONE THAT CAN PROVIDE SOME INSIGHT TO THIS PROLBLEM IT WOULD BE APPRECIATED. WE HAVE ASKED MECHANIC'S IN OUR AREA AND NOBODY SEEMS TO BE ABLE TO HELPWITH THE TOOLS NEEDED OR HOW TO FIX IT, PROBABLY BECAUSE OF THE AGE. PLEASE RETURN MESSAGE SOON THANK YOU. DON LIEBSCHER
RoyG
10-12-2004 17:27:12
 Re: brake information for a 1977 case 580c in reply to Don Liebscher , 10-12-2004 15:18:41
Take a pump oil can - fill it with brake fluid - get a peice of vacume hose that will just fit over the end of the spout and over the bleed valve on the slave cyl. - open the bleed valve and pump fluid back through the bleed valve and up to the master cyl. this will get the air out. MAKE SURE YOUR BARAKES USE BRAKE FLUID AS SOME USED HYD FLUID.
don liebscher
10-16-2004 06:30:47
 Re: brake information for a 1977 case 580c in reply to RoyG, 10-12-2004 17:27:12
thanks for the info roy it is appreciated. We didn't know what to do with it.
