oil capacity for 580CK
Patrick
10-11-2004 11:26:56
Buying the manual is a luxury I can't afford just yet. I'm changing the oil and filter on my "new" '67 tractor. Can anyone tell me the volume of oil I should put in it?
Also, I would like to get some tire chains, but they're very expensive. Anyone know where I can get used/cheap tire chains (16.9 - 24 on 15" rims as near as I can tell)?
Jim B
10-11-2004 18:58:46
 Re: oil capacity for 580CK in reply to Patrick, 10-11-2004 11:26:56
I asume you mean engine oil but here's all of them:
Engine:(Gas & Diesel) 4 qts + 1 for filter, SAE 20wt
Air Cleaner: (Gas) 2 pints, SAE 20wt
Air Cleaner: (Diesel) 2-3/4 pints, SAE 20wt
Trans & Diff Case: 17 Qts, SAE 90wt
Power Steering: 1 Qt, Case TCH
Torque Tube: [Clutch or Converter & Shuttle (power or manual) & hydraulic Reservoir]: 16 Qts, Case TCH
Loader: Initial= 8 Gal, Refil= 5-1/2 Gal, Case TCH
Loader-Backhoe: Initial= 19 Gal, Refill= 11 Gal, Case TCH.
Hope this helps
Esev
10-13-2004 18:13:01
 Re: oil capacity for 580CK in reply to Jim B, 10-11-2004 18:58:46
Is the Case TCH oil a hydraulic / transmission (hytran) type oil, or is it a plain hydraulic oil ?
Jim B
10-13-2004 20:10:06
 Re: oil capacity for 580CK in reply to Esev, 10-13-2004 18:13:01
As I understand it ... "TCH" stands for Transmission, Clutch & Hydraulic oil. So, I'd say, it's Case's version of what IH calls "hytran"
