VAC wiring diagram
John Larsen
08-17-1999 21:01:41
I am restoring a 1952 Case VAC and am at a loss as to how to go about rewiring. I have an I&T manual but it does not have a wiring diagram. It is a six volt system. Does anyone have a suggestion as to how I could go about getting a wiring diagram? Thanks for any help you could offer!
Jerrie Lott
08-18-1999 10:51:25
 Re: VAC wiring diagram in reply to John Larsen, 08-17-1999 21:01:41
I maybe am being a little critical but I can't believe that all the tractors that people get to restore have every bit of the wiring ripped out of them. I would ake the original wiring off and save it with each connection marked as to where it was connedted then it is just a matter of buying new wire and checking the lengths, cutting and putting new terminals on it. I have two VACs that I am working on and all of the wiring was there even though one had set seven years. I would not say it was functional but at least I could look at it tell where to put the new wire and how long to make the new piece. Just a suggestion
H. L. Staples
08-18-1999 14:08:14
 Re: Re: VAC wiring diagram in reply to Jerrie Lott, 08-18-1999 10:51:25
My Case service manual has a good wiring diagram for magneto or distributor ignition. It is Case publication number Rac258. I bought it a few weeks ago cost about $30.00 got it from the Case Dealer.
Wolfman
08-18-1999 06:23:11
You would be doing yourself a favor to change it over to 12 volt, however, I can mail or fax you a wiring diagram if you decide you want to definitely keep it 6 volt. Send me an e-mail if you're interested.
Regan
08-19-1999 15:07:02
 Re: Re: VAC wiring diagram in reply to Wolfman, 08-18-1999 06:23:11
i have an old vac and when i went and picked it up it had been setting in the pasture for eight years. the cows had eaten all of the wires to every thing. on my vac it has a 12volt generator and a 12 volt battery. it had a 6 volt coil so i just spliced in a regulator and the system works fine. i riged it up and after seven years of setting it fired off on the first crank, and on only two cylinders i had gotten two mixed up.
do you know of any vac's for sale?
Wolfman
08-20-1999 08:00:16
 Re: Re: Re: VAC wiring diagram in reply to Regan, 08-19-1999 15:07:02
What year is yours and what part of the country are you in??? I don't know of any whole tractors for sale right off, but I do know of a couple of good sources for parts. And is there a resistor in line as well, mine's mounted on the inside of the gauge panel. Put a new 12 volt coil on it last winter. Sounds like you're in pretty good shape on yours.
