Is Case S positive ground?
tj N.Dak
10-10-2004 17:55:14
We have a 1950 Case S and no manual, yet? Does anyone out there know if it needs to be positive ground hookup on the battery. If so...why? And would there be problems if I hooked it up Pos to Pos and Neg to Neg?
C. Amick
10-11-2004 09:45:15
 Re: Is Case S positive ground? in reply to tj N.Dak, 10-10-2004 17:55:14
Could mess up the voltage regulator. Some voltage regulators are set up for either neg. or pos. ground. Your ammeter needle will go the wrong way. Other than that you shouldn't do any damage. Should be neg. ground.
For a wiring diagram, go here:
http://www.villagephotos.com/viewpubimage.asp?id_=1953152
tj N.Dak
10-11-2004 13:22:45
 Re: Is Case S positive ground? in reply to C. Amick, 10-11-2004 09:45:15
Info was very helpful. Especially village photo.
Thank You.
JerryW
10-11-2004 11:21:45
Regulators do not like being hooked up to the opposite ground (neg wired pos or vise versa). Most regulators are stamped as to their ground orientation.
The regulator is the only thing in an old points ignition electrical system that is polarity sensitive.
Jerry
caseman-d
10-10-2004 18:04:33
Negitive ground. there was a post sometime back of the wiring diagram. I beleive Mike S posted it.
caseman-d
