Radiator and block drain
KCTractors
10-10-2004 17:39:56
I need to drain the the block and radiator on a 1941 SC. The farmer that i bought it from says it just water in it. I see a plug under the front pedestal between the radiator and the block and I drained that one, but is there any more ?
C. Amick
10-11-2004 09:22:40
 Re: Radiator and block drain in reply to KCTractors, 10-10-2004 17:39:56
That should take care of it. If it were my tractor, I would put a 50/50 mixture of antifreeze/water back in it. I think it would help stop some of the internal rusting in the engine block to leave antifreeze in it year round. I've taken these engines apart that have a pile of loose rust half way up on the rear cylinder sleeve.
