Need your Help Again
caseman-d
10-10-2004 17:24:12
Roger,
I was out plowing with an old case plow and and had a bearing go out of the culter wheel. I couldn't find any model number on the plow. I did find these part numbers:
W2250, hub to hold bearing in
2562 , spacers with zerks that centers the wheel between brackets. Also some other numbers I found. This is a 4 bottom, hydraulic lift. Any help would be appreciated.
Thanks
caseman-d
Third Party Image
Third Party Image
jon f
11-03-2004 09:07:27
 Re: Need your Help Again in reply to caseman-d, 10-10-2004 17:24:12
this coulter has tpered bushings insead of bearings. i have not been able to get new parts for these. you can get them at salvage yards though. if you dont have any neer you i cane help out out of minnesota.
