530CK Cyl Rebuild - Help
Mike Fallavolli
10-09-2004 22:22:38
Hi All.
I'm trying to attack my first hydraulic cylinder rebuild; the hydra-leveling cylinder on my '64 530CK. I built a spanner wrench and got the packing gland off okay but I can't get the rod/piston out. It came out about 5 inches and just won't move any more.
I finally removed the whole cylinder and brought it home. I made a jig with some pipes and a 4x4 and tried pulling it apart with my come-along but all I get is a lot of crackling wood. Am I missing something?
-- Mike
jimtx
10-10-2004 07:39:58
 Re: 530CK Cyl Rebuild - Help in reply to Mike Fallavollita, 10-09-2004 22:22:38
Did you use the hydraulics on your tractor to force it out?
Mike Fallavollita
10-13-2004 21:34:59
 Re: 530CK Cyl Rebuild - Help in reply to jimtx, 10-10-2004 07:39:58
No. First of all, since it is the hydra-levelling cylinder there isn't a valve that controls it directly. I certainly wish that I had a manual pump that I could have hooked it up to and just slowly pushed it out.
As it turns out, I hooked it back up to my jig and ignored the cracking sounds. It finally gave up and started coming out nice and easy.
Now all I have to do is get the nut off! ;-)
-- mike
Joe (Wa)
10-14-2004 07:58:14
 Re: 530CK Cyl Rebuild - Help in reply to Mike Fallavollita, 10-13-2004 21:34:59
Mike, the nut will typically be torqued to 500-600 ft lbs. Best to use an impact wrench as opposed to a 10' cheater.
Joe
