Identifying a Case.
Loren
10-07-2004 21:07:53
Friend bought a Case but doesn't know what model it is. To me it looks like 50's era, is a 6 cyl. diesel, has 6300X cast into the block right side, above the firing order. The manifold has 6333s cast into it, steering column has a 59XX cast into it. 18.4-34 rears, 18" fronts and only a drawbar. He said the kingpins he put in are 1" diameter and it has big diameter solid center hubs. The cylinders are pair siamesed, ala the Molines. Loren
Loren
10-08-2004 22:47:23
 Thanks all in reply to Loren, 10-07-2004 21:07:53
Looks to be a 600. Same colors as some I see here, can't tell you what those colors are though... Same frontend, same rear fenders, similar size. I figured it was a 600 but appreciate you all filling in the blanks.
caseman-d
10-08-2004 20:55:41
 Re: Identifying a Case. in reply to Loren, 10-07-2004 21:07:53
Case 500,s
Third Party Image
case 900's if it works right.
Third Party Image
caseman-d
10-08-2004 20:44:54
third party image
Here is a picture of a 600
caseman-d
Don Livingston
10-08-2004 08:16:46
6333A is the right side diesel manifold number of a 500 or 600. being it has 34 inch rubber, I would put it at a 600.
Don L.
John H-WI
10-08-2004 04:58:34
Maybe someone with a parts manual can identify the numbers. What color is it? In the fifties they made the 500, Flambeau Red, the 600, successor to the 500, Desert Tan with the engine and other various parts Flambeau Red. Also had the 6 speed transmission. The 600 was followed by the 900 and 900B. These were also Desert Tan but the styling was changed and the headlites moved to the top og the grill. Hope this helps a little. Serial number should also tell what year it was made. Give this if you can find the serial plate.
John Saeli
10-08-2004 04:53:04
Hey Loren: If the cylenders are cast in pairs, "It ain't no CASE". The CASE block is cast as 1. The heads cover 2 cylenders each. Sounds like a Moline to me. Moline also built large tractors for Massey in the 60's.
