Sc Rear Wheel Clamp Bolts
Glenn FitzGeral
10-07-2004 07:19:49
I have decided to replace the rear axel seals on my SC, putting other projects on hold a little longer. Should I be concerned about using heat to get those 8 bolts off? I've heard it will damage the cast-iron wheels. I have hit the nuts with a 4 lb. hammer to jar them loose. I then used my 3/4" breaker bar with a 3' pipe. If anything gives it's gonna be the wrench! I have tried tightening them a bit first. They're set on pretty good. What would you do? Thanks, Glenn F.
John Saeli
10-07-2004 17:14:45
 Re: Sc Rear Wheel Clamp Bolts in reply to Glenn FitzGerald, 10-07-2004 07:19:49
Hey Glenn: I'd leave the 8 bolts you mention alone, and take the whole wheel ass'y off at the axle. It's all gotta come off anyway.
Glenn F.
10-07-2004 18:19:55
 Re: Sc Rear Wheel Clamp Bolts in reply to John Saeli, 10-07-2004 17:14:45
I am referring to the 8 bolts on the axel clamp; four on each side. Glenn F.
wade king
10-07-2004 19:36:34
 Re: Sc Rear Wheel Clamp Bolts in reply to Glenn F., 10-07-2004 18:19:55
I just finshed a Case with those clamps, cut them out with a reciprocating saw in the cut. Hope you do not want to reuse them anyway!
Scott T
10-07-2004 15:09:51
Speaking of rear wheel clamps for an SC,..... Where could a person get new ones at??? I need a set for each rear wheel. I just need the clamp part. Will any other models or makes interchange with them ?????
C. Amick
10-07-2004 14:18:14
I would try some P.B. Blaster and an impact wrench before using heat. Are the tubes and tires any good? I have a feeling you will find that some of the bolts will need to be replaced due to rust damage.
RobertTX
10-07-2004 08:10:22
Use an impact wrench, it is much less likely to break the bolt, and a lot more likely to get it loose. Start out with the wrench on a lower setting, try both directions, increase wrench setting until it begins to move. Once it starts moving, don't let up, bring it all the way out. I have a L with the cast iron wheels. I broke a bolt using hand wrenches, got all the rest of them out with the impact. They were all necked down from corrosion. I rarely break a bolt with the impact, twist a few off with hand wrenches. Soak with a penetrant first.
DCTOM
10-07-2004 08:00:11
HEAT
