730 breaks
Mikey
10-06-2004 18:22:59
The breaks on my 1966 730 (741) have been bad for years. But now with my kids around the yard and having a loader mounted in it I want to get this put-off problem fixed before winter.
Is this something I can do "under the shade tree" or should I spring for a service call?
I live in Wisconsin and use this tractor to plow snow in the winter, and general yard work the rest of the year, as I quit farming in 1993.
My Dad bought this tractor new, has about 3600 hours on it, was shedded all of it's life, and I hope to restore it someday.
Lamont
10-08-2004 02:17:53
 Re: 730 breaks in reply to Mikey, 10-06-2004 18:22:59
Mikey,
When you have it apart, replace the actuating balls between the spreader plates with balls that are 1/16 inch larger. You'll be surprised how this helps. These are available at most bearing suppliers.
R.D.F.
10-07-2004 07:03:43
Give us a call @ 920 295 3278, we have most of what you may need here. There are quite a few parts we check when we do brakes on these that make a lot difference in final performance. Dale
Forgot to mention
10-06-2004 19:30:12
Sorry, forgot about the adjusting nut. You could try to tighten them up a bit. It didn't work for me, but you may get lucky. There is an adjusting on top of the "drums" that you could try to turn. If I remember right, all that is required is a 3/4 wrench.
SHeiserman
10-06-2004 19:23:31
I'd say fix it. It isn't hard to do and they're still available from the dealer. It cost me right around $100 to do both sides. It's been a little over two years ago since I did it, so they may be a little higher now.
Mikey
10-06-2004 21:02:46
 Re: 730 breaks in reply to SHeiserman, 10-06-2004 19:23:31
I remember doing that with a friend who worked for a Case dealer in the back shop (now out of buessness) back in 1980. That was the last time anything was done to these brakes.
SHeiserman
10-07-2004 02:55:05
 Re: 730 breaks in reply to Mikey, 10-06-2004 21:02:46
At 25 years between brake jobs you may even have a speck of rust or two on the actuating balls. I had trouble with the right brake grabbing a year or so after I replaced the discs. Shined those balls back up and that helped, but it still does it every once in a while.Good luck.
