Need a 3 1/2 Sleeve for Case SC
jbnova
10-06-2004 09:11:47
I bought 2 case SC tractors. One motor had been sitting out in the open and was stuck. It had the 3 5/8 bore and all the sleeves were cracked. The other tractor has the 3 1/2" bore but one sleeve cracked when the block froze. I now have 4 good 3 1/2" pistons and 3 good sleeves. Does anyone have 1 good sleeve they will part with or know where to get one? I thought about checking with the local machine shops and seeing if they could make one. Any ideas or help would be greatly appreciated.
C. Amick
10-06-2004 13:38:57
 Re: Need a 3 1/2 Sleeve for Case SC in reply to jbnova, 10-06-2004 09:11:47
I need some 3-11/16" SC sleeves and I had a local machine shop tell me that they could make them, if I could find the material (cast iron blank). I found a source for the cast iron, but haven't gotten around to having the sleeves made. I am probably looking at $125/sleeve. If interested, email me and I will give you the name and phone number of a couple possible cast iron suppliers. Most of the used sleeves are rusted really badly on the exterior and you may have problems getting the O-ring to seal properly.
george md
10-07-2004 18:23:48
 Re: Need a 3 1/2 Sleeve for Case SC in reply to C. Amick, 10-06-2004 13:38:57
C Amick, If the oring grooves and the flange is good , I bore the wet sleeve and install a dry repair sleeve in the wet sleeve . It is easiest when you have a block to bore them in . if you don't have a block then make a fixture to do them in a small engine fixture. I can send you some pictures if you want to see how .
george
C. Amick
10-08-2004 05:53:29
 Re: Need a 3 1/2 Sleeve for Case SC in reply to george md, 10-07-2004 18:23:48
I am in the same condition as the other guy, I don't have anything to bore. Someone let water get into the cylinders and freeze. It cracked the sleeves that were in the engine.
george md
10-08-2004 10:19:15
 Re: Need a 3 1/2 Sleeve for Case SC in reply to C. Amick, 10-08-2004 05:53:29
C Amick,
I have some ideas , got to go do a grade job now ,be back after dark. Do you have any of the cracked sleeves left. Send me an email [email protected]
george
