SC oil Pressure gauge.
bernsy MN.
10-05-2004 20:02:18
The oil pressure gauge does'nt work, It worked before I blew out the line, {read 20 lbs, wanted to see if it would increase}, now nothing. The engine runs smooth & quiet. Anyway can the gauge be cleaned, or replaced, anyway to test it,,,,, ,,,, thank, Bernsy P.S. When I cleaned the heavy metal and gunk out of the bottom of the oil filter canister it leaked like a seive through a newly exposed pinhole. JB to the rescue.
Paul f
10-06-2004 06:01:16
 Re: SC oil Pressure gauge. in reply to bernsy MN., 10-05-2004 20:02:18
The mechanical guages have a bourdin (sp??) tube. Sounds like the blowing out may have ruptured the tube :-(
The tube in the guage has a curved shape and is attached to the needle...as the pressure in the tube increases the tube straightens out moving the needle...could also be tube and needle got disconnected but doubt that it would be a DIY fix
Bernsy MN.
10-06-2004 07:05:42
 Re: SC oil Pressure gauge. in reply to Paul f, 10-06-2004 06:01:16
I took the line off at both ends when I cleaned it, Maybe it has to be bled? Also cleaned the oil sump screen. Hopefully the gauge is still allrite.
Paul f
10-06-2004 08:35:42
 Re: SC oil Pressure gauge. in reply to Bernsy MN., 10-06-2004 07:05:42
You might try gently squirting some solvent into the gauge inlet. Don't know if bleeding helps...I have translucent nylon tubing on my DC and there are frequently apparent bubbles in the line but guage works OK
chrpmaster
11-05-2004 07:45:35
 Re: SC oil Pressure gauge. in reply to Paul f, 10-06-2004 08:35:42
I have the same problem with my gauge on my SC. It never goes above 20 lbs and when I tried to blow it out it went to 20 but not beyond. Luckily it still works but maybe I need to get a new one. Where would I go for one?
