david Brown 1210 constant pumping lever
Stephen C
10-05-2004 00:32:29
I have a David Brown 1210. I cannot find the correct lever sequence to keep the constant pumping lever in place without holding it. Any Ideas.
Many Thanks!
stephen c
10-06-2004 00:49:55
 Re: david Brown 1210 constant pumping lever in reply to Stephen C, 10-05-2004 00:32:29
I am trying to run a hedge cutter, and yes i have tied it back with bale string. Thanks everyone
Elmer
10-06-2004 05:02:38
 Re: david Brown 1210 constant pumping lever in reply to stephen c, 10-06-2004 00:49:55
A power beyond would make it work slick. Is there a separate control valve to operate the hedge cutter? Email me direct [email protected]
Elmer
10-05-2004 15:01:27
What are you trying to accomplish? Do you want to feed a loader?
richard U.K.
10-05-2004 14:24:47
A latch was available as an option to hold the lever back. It fitted on the screw at the top of the quadrant and droped down on to a peg on the lever.Get one from a breaker, make one, or use farmers friend (bale string!)Hope this helps
joe e-tx
10-05-2004 07:13:10
if you are talking about the lever to operate the remote cylinder? such as a loader or baler,it would need to be tied in to stay on.for full time operation you would need a power beyond plate.elmer has them well worth to money
joe
