DC rod bearings
Scott KY
10-04-2004 18:41:06
My 39 DC has low oil pressure and all of the shims have been removed from the rod bearings. I was wondering if it is possible to use rods with replaceable bearings from a different series of tractor with the same bore and stroke. Any body tried this?
Larry Martin
10-05-2004 17:16:26
 Re: DC rod bearings in reply to Scott KY, 10-04-2004 18:41:06
Scott, I have some used rods in the barn but I don't know how many. I will check tomorrow and let you know on this post.
C. Amick
10-05-2004 10:10:34
Ask around at machine shops. There should be someone in your area that could pour new babbit. If you file down the caps, it leaves you with an eliptical opening. Engine blocks that have had the main bearing caps filed down, have to be line bored before new bearings can be installed.
Camboted
10-04-2004 22:56:36
Never heard of any that would interchange. If you find one let us know. Otherwise you can have your babbit re-poured, probably the best choice in my opinion.
Scott KY
10-05-2004 04:37:22
 Re: DC rod bearings in reply to Camboted, 10-04-2004 22:56:36
Do you know anyone who can repour the babbits?
Camboted
10-05-2004 06:07:59
 Re: DC rod bearings in reply to Scott KY, 10-05-2004 04:37:22
I forgot to mention the "El Cheapo" approach. If you have some babbit surface left just file the caps. You can save a bundle and it will run fine.
Paul f
10-05-2004 05:26:55
Check with Don Livingston 507-433-0073 Mornings best
