Starts with hotwire, but not with key
Patrick
10-03-2004 11:43:17
I just bought a 580CK (with loader bucket only). The key was lost, so I put in a new ignition switch, being meticulous in diagramming and moving wires from the old switch to the new. (The tractor worked with the old switch when used last fall). I had to hotwire it to bring it home. Anyway, with the new key switch, my guages and lights come on fine, but the engine does not crank or even click. The key does turn it off, however (after hotwiring the engine). Today I replaced the solenoid with the same results. The battery is completely dead, requiring jump-starting. I can't connect the dots and my knowledge of mechanics (and electrical systems even more so)is pretty puny. Any ideas as to what might be wrong?
george md
10-04-2004 09:06:39
 Re: Starts with hotwire, but not with key in reply to Patrick, 10-03-2004 11:43:17
Patrick,
Many times there is corrosion on the ammeter
terminals , need to remove and clean. I have a
580 B that does that .
george
jstpa
10-03-2004 21:10:29
It sounds like the wire from the switch to the solenoid is broke somewhere. Get a helper and have them hold the switch in the start position while you put a test light on the little wire at the starter, If you don't get a light start tracing that wire back till you find the bad spot.Or if it has safety switches on it that could also be the problem. jstpa
