SC Hydraulic Lever Loose
Glenn FitzGeral
10-02-2004 21:09:15
My SC has a dual spool hydraulic pump. The one spool has a very weak spring inside...? If you barely bump the hyd. lever it will lift/drop. I have not looked at it at all yet, but is there a spring that can be replaced or adjusted? Thanks, Glenn F.
Bruce Nelson
10-03-2004 06:19:22
 Re: SC Hydraulic Lever Loose in reply to Glenn FitzGerald, 10-02-2004 21:09:15
There are three springs that have a part in centering the spool. (each spool). The one that does the most is a plunger spring. It provides pressure on a pointed plunger that fits into a notch in the spool, centering it. There is one spring and plunger for each spool. These require removal of the hydraulic unit and separating the gear pump from the spool body for replacement. There are two other springs (on each spool) that have a lesser, but noticeable effect on centering the spool. These are located at the ends of each spool and apply pressure on the ends of the spool through a check ball and a short little rod, also called a spool. These springs are easily replaced by removing the swivel fitting that connects the hose to the pump body. Be careful when removing the fitting not to lose the ball and small rod (spool). All these parts are available from Case. The springs cost around $6.50 each. Bruce
