firing order of a VA Case
Walter Sasyniu
10-02-2004 20:23:38
Could someone give me the information on the firing order of a VA case, one of the last ones built. Also which piston is #1, the one by the rad. or the one by the driver. I can"t locate my tech manual, guess I put it in a safe place. With thanks, Wally
Joe (Wa)
10-02-2004 21:08:04
 Re: firing order of a VA Case in reply to Walter Sasyniuk, 10-02-2004 20:23:38
1-3-4-2. Firing order should be on the top of the cylinder head between the valve cover and manifold. #1 is front nearest radiator.
Joe
F-I-T
10-03-2004 05:54:30
 Re: firing order of a VA Case in reply to Joe (Wa), 10-02-2004 21:08:04
And if you have to let one sit through a hurricane, it's kind of like:
--4-,--4-,-34-,-34-,-3--,-3--, 13--,13--,1--2,1--2....
Joe (Wa)
10-03-2004 11:07:22
 Re: firing order of a VA Case in reply to F-I-T, 10-03-2004 05:54:30
Frank,
The submarine I was on in the 60's had a snorkle induction & exhaust system called "GUPPY" for greater underwater propulsion.
Perhaps you might want to look into that if you plan to continue living in Floridacane.
Joe
