Hydralic pump???
Keith-OR
10-02-2004 19:40:46
I have a freeman frontend loader on a Case VAC 14, the front pump is not quit fast enough or has enough pressure to run loader very fast, WAS WONDERING if I could also run the pump on the output shaft for the front loader and cam drive for the 3 point. Have figured out how to increase hydralic fluid reserve so there would be enough for both systems
Thanks... Keith
BLR
10-04-2004 11:45:45
 Re: Hydralic pump??? in reply to Keith-OR, 10-02-2004 19:40:46
Keith,
I have a VA with a front end loader that operates off of the engine driven pump that runs the eagle hitch. To accomplish this I have inserted an open center control valve in the high pressure line between the pump and the eagle control valve. Additionally, I set the pressure relief valve in the open center valve to release at 450 psi. The Eagle pump is designed for 800 psi, and at 450 psi the loader lifts more than the tractor should carry(lifts the rear wheels off the ground). The loader has 3 inch cylinders and I don't feel that it is too slow. Installation of two way cylinders will solve your reservior problem, since all that happens is you exchange oil.
Keith-OR
10-04-2004 12:34:16
 Re: Hydralic pump??? in reply to BLR, 10-04-2004 11:45:45
Thanks for the info, filed it in folder for case VAC. Sold tractor yesterday.Individual seems to be happy with the way loader works, so as long as they are happy withit all is well. I do have two way cylinders already on loader. I just felt it was to slow in reaction time.
Thanks Again...Keith
JerryW
10-03-2004 14:40:44
I do not believe that it would work without a lot of engineering because the belt pulley driven pump is a high pressure low volume pump amd the magneto hole drive pump is a low pressure high volume pump comparatively.
Not only that but the mag hole pump runs all the time the motor is running and the belt pulley pump disengages with the clutch.
I would think that replacing the front pump with a bigger one is the easier answer.
Jerry
Keith-OR
10-03-2004 20:18:51
 Re: Hydralic pump??? in reply to JerryW, 10-03-2004 14:40:44
Thanks Jerry. did a research in the archieves,found that the pump on the belt pully was low volume and would only run when clutch was ingaged. So like you pointed out would not work to run the loader. Will have to look for a larger pump for the front...Any ideas where to start looking.....Keith..... again thanks
JerryW
10-03-2004 21:11:46
 Re: Hydralic pump??? in reply to Keith-OR, 10-03-2004 20:18:51
Somewhere on this forum someone once said that certain combines and some of the VAI loader tractors had a larger capacity pump.
Myself, I just plan on going to my local hydraulic surplus and finding one that will fit and somehow making it fit. It helps being a machinist.
Jerry
Keith-OR
10-04-2004 12:27:15
 Re: Hydralic pump??? in reply to JerryW, 10-03-2004 21:11:46
I have pumps that will pump a lot more volume and pressure, They are off 3 stage forklifts. But the only problem is mounting one. Well don't really need it now, sold the tractor yesterday. They seem to be happy with the way loader works. So all is well..... Thanks Jerry will file info away for future referance.
Keith in Gods country
