tractor heating up
Kelvin C
10-01-2004 17:34:57
Just bought a 1175 Case. Water pump was leaking and I replaced it. When working tractor, temperature guage read "hot". Antifreeze leaked out from the overflow hose. Filled rad with water, started tractor and water was coming out of overflow hose at a steady flow; tried to release rad cap but there was too much pressure. Any ideas for what the problem may be?
Brian in Ohio
10-02-2004 06:17:04
 Re: tractor heating up in reply to Kelvin C, 10-01-2004 17:34:57
Is there water in the crankcase? I leaning toward John's way. Sounds like you've blown a head gasket.
John Saeli
10-01-2004 17:55:26
Hey Kelvin: I hope S. Heiserman is correct, but I fear you have a blown head gasket, cracked head or cracked sleeve. Has this tractor been ethered?
SHeiserman
10-01-2004 17:52:45
Air lock or maybe loose fan belts?
