Case model CC axle seal leak
James Dreher
10-01-2004 06:39:01
Does anyone know how to remedy a rear axle seal leak on this tractor? I do not fully understand this design, but believe there to be no actual seal, and the sealing is dependant upon the heavy grease applied at the outer fitting. I have put enough grease in there to choke a horse, and the axle still leaks.
Any ideas?
Thanks
Joe in Ohio
10-03-2004 17:16:10
 Re: Case model CC axle seal leak in reply to James Dreher, 10-01-2004 06:39:01
My 1937 CC leaked too. Mine does have seals. Chicago Rawhide #37533.Wasn't to bad to change.
FarmallB
10-03-2004 12:17:25
Ive used my grandads 34 CC in farming for around 30 yrs now. Its got grease cups. Like you, i ran the grease through them, and finally the right one sarted leaking. I finally realized that the grease is sucked into the axles as needed from the grease cups. I, when plowing, especially, but in anything else where im going to b e using her for several hours will turn the cups say 2 full turns each, If I feel immeadiate resistance, I only turn 1/2 . Mine dosent leak now, but then I farm and park it on flat ground. Good luck
